Crazy Project Car
Crazy Project Car
This is my crazy project car that I am building. Its probally going to take me a year in a half to build but when its done its going to be sick. I was just wondering if anyone has any suggestions on any combos that they have heard worked well with others. Please, I would like to hear ALL SUGGESTIONS. Also, just for fun... what do you think the RWHP and 1/4 will be with this set up in a 88LX (dont forget to take weight into consideration...no a/c, p/s, no backseats, fuell cell, trunk mount kit for battery,etc, etc. etc.)
DSS Racing 331 Pro Bullet Level 20 CNC Shortblock
DSS Racing Main Support System
DSS Racing Flat Top Pistons
AFR 185 Heads
Moroso 7qt. Race Pan
Comp Cams Rockers
Custom Grind Comp Cam (around .550 - .570)
Performance Automatic Comp C4 (reverse manual valvebody)
Performance Automatic Transbrake
Performance Automatic Custom 10' Pro Launch Torque Converter (want to go a little bigger though)
Strange Aluminum Driveshaft
Moser 8.8' Rear
Full D&D Tubular Suspension (Strange 10 way adj. struts & shocks) (not sure on the suspension yet)
Strange Pro Street 4:10's
Flamming River Manual Rack & Pinion
Edelbrock Performer RPM Intake Manifold (upper & lower)
Edelbrock RPM Adj. Nitrous Kit (150-300) (debating on that big of nitrous shot, motor most likely will not handle all of that)
Aeromotive Competition Fuel Kit
Full MSD Ignition
Electric Fan & Waterpump
Battery Trunk Mount Kit
Fuel Cell
AFR 185 Heads
Comp Cams Rockers
Moser 8.8' Rear
Full MSD Ignition
Fuel Cell
RE: Crazy Project Car
sounds good personaly i'd go with a TKO600 and keep the power steering ...but that's just me. what kind of CR are you going with ? what are you using for tuning ? what injectors, fuel pump, MAF ? with stock compression i'd expect between 420-450 rwhp (without n2o)
I hope to do something like that one day. Looks like your gunna be dumpin a lot of cash into your stang but im sure itll be worth it. Are you doing all the labour or having someone to do it? good luck by the way.
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
