valve covers wont fit...
Old 10-29-2005, 01:08 PM
StangStang
StangStang's Avatar
Default valve covers wont fit...
I installed 1.7 roller rockers from crane cams and now the roller rockers hit my baffle in my calve cover. I cant find a set of taller valve covers. What should I do?? 92 5.0 LX
StangStang is offline
Old 10-29-2005, 01:14 PM
angcobra
angcobra's Avatar
Default RE: valve covers wont fit...
there are several brands out there that are tall enough to clear the rockers (Ford Motor Sport for 1). The next issue you may have when you put on the taller valve covers is the throttle body/accelerator cable arm may hit the valve cover. If you use the taller valve covers (for most intakes) you also need a spacer between the lower and upper intake.
Alternate, I have 1 engine that I have taken the baffles out of the stock valve covers, if you do this you have to deal with the oil splash at the valve cover openings.
angcobra is offline
Old 10-29-2005, 01:36 PM
Madskillz306
Madskillz306's Avatar
angcobra has the right answer for ya man, get some tall boys on there and a spacer between upper and lower intake. looks just like the gasket you user but like 1/2 " or so type deal. I have 1.6 on mine but my engine came with tallboys on there.
Madskillz306 is offline
Old 10-29-2005, 02:11 PM
stanglx2002
stanglx2002's Avatar
you could grind the baffle down some so they dont hit or get tall covers with a 3/8 - 1 in spacer
stanglx2002 is offline
Old 10-29-2005, 02:47 PM
StangStang
StangStang's Avatar
thanks for the help, one thing I left out and this may make the difference. I have edlebrock upper and lower intake manifolds part #3821 @ http://www.edelbrock.com/automotive_...l-inject.shtml
I am not sure if there is a difference in height with the new manifolds.
Old 10-29-2005, 08:33 PM
silver91gt
silver91gt's Avatar
all I did was take out the baffle under the oil fill snout.
my 1.7s fit nicely under the stock valvecovers.
silver91gt is offline
Old 10-30-2005, 01:15 PM
angcobra
angcobra's Avatar
do you have the tall metal spout?
If not be carefull with what you use to cover the spout. Just a breather will allow oil to be thrown out.
ORIGINAL: silver91gt
angcobra is offline
Old 10-30-2005, 01:17 PM
vfast
I ♥ Acer
vfast's Avatar
they make an extra thick V/C gasket to help this problem
vfast is offline
Old 10-30-2005, 08:31 PM
Tims 88GT
Tims 88GT's Avatar
just cut the baffle out and it will be fine.
Tims 88GT is offline
GimpyHSHS
19
12-19-2023 01:12 PM
mrtrodonet
09-19-2020 03:12 PM
winner99
10-01-2015 01:06 PM
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
Quick Reply: valve covers wont fit...
