Spark Plug Wires - MustangForums.com
Spark Plug Wires
Old 02-14-2019, 10:22 AM
jeedee
Default Spark Plug Wires
1995, GT, Edelbrock Intake and Heads, Headers, MSD, CAI......looking for suggestions for replacing spark plug wires. Owned car since 2004...never changed wires, though I've only put 4000 miles on car since 2004. Having no problems, but wondered if wires degrade after so many years.
Thanx......Jeedee.
jeedee is offline
Old 02-14-2019, 02:52 PM
drhoward
Moderator
drhoward's Avatar
Never hurts to change them, I've used accel and msd. I've never noticed much of a difference between the two some other members here might have a preference for one versus the other.
drhoward is offline
Old 02-14-2019, 03:19 PM
jeedee
Thanx for the input, drhoward. Have a few months 'til Spring to decide.
jeedee is offline
Old 02-14-2019, 05:25 PM
TrimDrip
TrimDrip's Avatar
I went with the numbered ones from ford racing after i sold the V3. I had msd wires before then.
TrimDrip is online now
Old 02-14-2019, 06:01 PM
drhoward
Moderator
drhoward's Avatar
I had to use a custom length kit to clear my gt40p headers, in fact i think I have a couple of each on my car right now, lol (accel and msd that is)
drhoward is offline
Old 02-14-2019, 07:11 PM
Urambo Tauro
Urambo Tauro's Avatar
Good question. But your mileage and age figures are misleading, unless you're trying to say that the wires were replaced in 2004 and have only 4000 miles on them.
Without a good sense of age/mileage, the best advice I can offer is to inspect them. Check the wires visually for any cuts, cracks, tears, or burns. If they look ok, ohm them out. I wish I could tell you how many ohms per foot is acceptable, but the numbers that are coming up in a google search vary wildly, and I'm not seeing a spec in the manual either. Anybody else know?
Urambo Tauro is offline
Old 02-15-2019, 06:49 AM
wbrockstar
wbrockstar's Avatar
My Chiltons manual states to replace the wires after 50k miles or 60 months.For testing the wires for ohms value,remove the distributor cap,but leave the plug wires attached.Remove the wire from a spark plug then test it by touching one meter lead to the spark plug end of the wire while touching the other lead to the plug wires distributor cap post on the underside of the cap.The value should be 7000 ohms or less per foot of wire length.So if the wire is 1.5' long,resistance should be <10,500 ohms.Use this process to do the remaining wires.
wbrockstar is offline
Old 02-15-2019, 10:16 AM
jeedee
Thanx all for the replies. My GT has 88,000 miles on it. Don't know when/if the wires were ever changed. They look OK. Car sits all winter. Had to replace the rotor.....corrosion. So, I think that it wouldn't be an expensive job....so may as well do it. Will probably put the GT up for sale soon.....just don't drive it enough.
Again, thank you for all those replies.
Charlie.
jeedee is offline
Old 02-15-2019, 04:48 PM
wbrockstar
wbrockstar's Avatar
If its currently misfiring,hesitating,hard starting in damp weather or the plug wires are emitting blue arcs (start the car & while its idling use a spray bottle to lightly dampen the plug wires at night with the hood up & the hood light off),go ahead and replace them.If the car is running just fine and you're getting ready to sell it,I wouldn't bother spending any money on it thats not necessary.If an issue is present that could negatively affect the final outcome of the sale,because of how the car is running,that might require you to spend some cash before you attempt to sell it,otherwise I wouldn't bother.
Old 02-16-2019, 07:43 AM
jeedee
Yeah....I've thought of that, wbrockstar. Each Spring, I put the battery in, and vroom......fires right up. Just one more Summer....heh....it's such a good runner....no misses, no arcing, etc. Funny, how someone could get attached to a car.
Thanx for the reply.
jeedee is offline
BRENSPEED
08-25-2011 12:43 PM
SON1C
03-08-2011 07:25 PM
randyg
12-24-2006 09:13 AM
91LXStang2727
04-21-2006 04:08 PM
Dejavu
01-18-2005 07:56 PM
Quick Reply: Spark Plug Wires
Featured Sponsors
