timing chain.....
Old 10-31-2005, 09:35 PM
94ford5liter
94ford5liter's Avatar
Default timing chain.....
okay i'm sick of this ****, the timing chain must be the problem. I don't know if it's slipping really bad or what, but we just adjusted the timing and day by day the car starts to ping more and more. Anyone ever had a similar problem? If it's not the timing chain, something inside the motor has to be bad. Because the car is way slower than it should be still.
94ford5liter is offline
Old 10-31-2005, 09:37 PM
angcobra
angcobra's Avatar
Default RE: timing chain.....
Timing chains do not slip.
A few more details please.
angcobra is offline
Old 10-31-2005, 09:49 PM
94ford5liter
idk wtf it is then, im getting really tired of this car, getting ready to sell it. But its exactly what i said. I just adjusted the timing a couple days ago, and there was no pinging. Now after a couple days its starting to ping more and more. It seems like the pinging gets progressively worse whenever i floor the car.
Old 10-31-2005, 09:52 PM
angcobra
angcobra's Avatar
What are you setting the timing at? What octane fuel are you running? What mods do you have?
angcobra is offline
Old 10-31-2005, 10:09 PM
92hatchLX
92hatchLX's Avatar
What are you talking about, if you have a lot of miles on a timing chain it can slip or snap.
92hatchLX is offline
Old 10-31-2005, 10:19 PM
angcobra
angcobra's Avatar
ORIGINAL: 1991_5.0_Convertible
Chains can jump a tooth, but they do not slip, if it jumps a tooth, time for a new chain. If a chain is stretched, you can see the timing jumping around at idle, but when the engine is under load the chain will be tight on the loaded side.
angcobra is offline
Old 11-01-2005, 12:32 AM
1990mustanggt
1990mustanggt's Avatar
There is a very stong possibility that it is the timing chain. They will loosen up and even jump teeth. The thing is, if it had jumped a tooth you would more then likely know because it could bend valves.
Now something else you might want to consider checking into is the computer. The 1994 and 1995 5.0 computers were bad about finding ways around mods and chips. You could disconnect the battery to reset the computer and within a few days it would find away around whatever you had done to it.
1990mustanggt is offline
Old 11-01-2005, 12:50 AM
Quik
Quik's Avatar
you chain isnt slipping. a fawking belt slips. a chain stretches. i just swapped a chain with 174k miles on it and it didnt have that much more slack then a new one. this dude beats his car to death. so dont think its you chain, it can be but i doubt that.
for ***** and giggles, pull out dist and check the gear on it to see for excessive wear or any missing teeth. the stock gear can wear
if you lived close i would look at it but you live in cali so that does you no good. if you have pinging maybe something with the EGR system causing issues since you had issues with this before.
go to a dyno and get a base run. this will tell you your A/F ratio and see when the car is leaning out
Quik is offline
Old 11-01-2005, 05:57 PM
94ford5liter
once again it was something minor, and i feel like a real idiot, and the car runs great now. But anyways I have decided that I am going to sell the car and buy a notchback due to the weight difference. Feel free to message me if anyone is interested, car has many new parts on it. I always think something is serious wrong wiht my car whenever anything goes bad, because before i had a 99 grand am, and whenever anything went bad, it was way serious lol.
Old 11-01-2005, 06:17 PM
1990mustanggt
What was wrong with it, if you don't mind me asking.
Quick Reply: timing chain.....
