Exhaust Wrap
RE: Exhaust Wrap
i called summit and they said i need 2 rolls so that is what i bought and ties to hold them. I hope i can wrap them on the car if not i will take them off which is probably better.
i bought the wrap to cool down the engine bay and to stop melting/collapsing clutch cables. I just bought the MM Clutch Cable kit that uses the OEM style clutch cable which is surpose to be the best cable you can buy so thats what i got. I have been though 5 cables im not going though another one
RE: Exhaust Wrap
What are LT's? It takes more than you would initialy think. Using 1" wide wrap, if you managed to wrap an 1-5/8" primary with no overlap you would use 5.2" of length per inch of tube. However you have to have overlap, so subtracked about 1/4, and then you have to factor in the ends which will use much more. There is at least 40" of pipe on each shorty header.
80*5.2=416*1.25 (for overlap) = 520 + 48 (minimum for collecter ends) + 48 (heads ends) = 616"
That's 51' 4" with zero slack, and if you have ever wrapped tubing, it always takes more.
