View Poll Results: A poll
heads?
11-04-2005, 03:10 PM
RE: heads?
thanks for your help... i'm leaning towards the AFR if i can get more details about the valve clearance
11-04-2005, 03:13 PM
RE: heads?
04-13-2006, 04:06 PM
RE: heads?
go to trick flow.
04-13-2006, 04:10 PM
RE: heads?
Um..... I would not go with 205's on a 331... just my opinion. They are too big for a 331 street car. I personally would go with 185's and they would be perfect.
04-13-2006, 04:18 PM
RE: heads?
AFS's either way...
Trick-(you in to thinking they)-flow are decent heads for a budget build, but if you want to make horsepower, do it right the first time...
04-13-2006, 06:35 PM
RE: heads?
The biggest advantage to the TW's is that the valves aren't inline so you can run more lift w/o the clearance necessary for the AFR's or other heads and the valves are bigger than the 165's--which are $300 more.
I agree that a 205 head is too much for a 331. Bigger isn't always better, same w/ cams....
GimpyHSHS
19
12-19-2023 01:12 PM
mustangheaven
01-03-2016 11:20 AM
kevsgt
10-09-2015 10:12 PM
Florida Regional Chapter
09-30-2015 08:04 PM
Drastang
09-30-2015 03:48 AM
88,
blowers,
cam,
density,
e3030,
emissions,
fordscarb,
gt40p,
heads,
legal,
mustang,
rocker,
specifications,
speed,
studs,
work
