cost for tranny swap?
RE: cost for tranny swap?
you are going to need the tranny, the crossmember, shifter, bellhousing, flywheel and bolts, clutch and pressure plate, throw out bearing, piolet bearing, clutch forke, clutch cable, clutch pedal and thats all i can think of right now, if you start buying new stuff then it might get expensive.
the hardest part is finding the conversion parts the hardest part of the actual swap is putting the clutch pedals in i started on mine i am in the middle of the swap i have the pedal assembly if anybody is doing this swap make offer
i did mine. i got mine off ebay with a rebuilt tranny for 600 but i had to get a clutch flywheel and some bolts but not too bad. the pedals are a pita you will struggle with them. youll want to d a gear change mine has 2.73s and it dosnt like it too much.
jwog666
12-27-2021 08:09 PM
Matt's 95 Stang
10-05-2015 07:16 AM
