help please
Old 11-07-2005, 02:05 AM
jasonsvt
jasonsvt's Avatar
Default help please
my car has started a weird backfire/popping only between 4 and 5 on the tack,i did find a vacuum line that was off,so i put it back on,and something tripped the check engine light,the egr line was never off or moved,so thats ok,but i did some switching on the lines and now the car is better,and the light doesn't come on now,but the weird quick throttle high rev backfire/popping is still happening,but only between 4 and 5 on the tach,and only under super fast throttle.....anyone had a similar experience?something to check maybe? 94 cobra ...long tube headers,no cats,no smog,bbk cold air,flow masters,off road h pipe,3:73's,pro 5.0 shifter,180 t stat....thats all ,for now.....b cam and suspension in the next couple of months
jasonsvt is offline
Old 11-07-2005, 02:11 AM
smoker40
smoker40's Avatar
Default RE: help please
take off the battery cables for 10 mins.if you got it right should correct prob.
smoker40 is offline
Old 11-07-2005, 01:11 PM
waxyourboard
waxyourboard's Avatar
Does it happen when it's warm? or only cold? Also check timing?
waxyourboard is offline
Old 11-07-2005, 01:51 PM
89stanglx
89stanglx's Avatar
my car did the same thing when i set the timing to 14, when i would go wot at high rpm it would pop; but at 13 it does not do it.
89stanglx is offline
