Rear Main Seal
Rear Main Seal
I was under my car yesterday getting ready to drop the tranny to replace the clutch. And i noticed a BIG puddle of oil. It wasnt coming from the oil pan, but rather leaking down from the front of the bellhousing(where it attaches to the engine) Is this a sign of the main seal crapping out, it only seems to happen after i start the car and let it run.
RE: Rear Main Seal
i know of someone who could build and purchase a LS1 and run 11s but that isnt a mint shell either
but yea that sounds about right. normal for stangs to leak there. my notch does
RE: Rear Main Seal
lol i think it a catchy little phrase, one of my friends told me it is probably the rear main seal, but it just now started thats why i was worried it has never leaked before
RE: Rear Main Seal
Yeah..i'd say it's a safe bet that it's your rear main seal...what color of oil is it? If you're going to be doing the clutch, might as well remove the fly wheel and while it's out being resurfaced, put a new main seal in there.
RE: Rear Main Seal
The seal itself is cake..it's getting to it that's a pain!! You have to jack the car up as high as you can and put it on Jackstands, use the floor jack to support the tranny, pull the driveshaft, the tranny mounts, battery cable of the starter (after you've disconnected the Negative of course, bellhousing bolts, then back the tranny out.
On a manual tranny you have to remove the flywheel and on the Auto you have to remove the flexplate. Then when you're putting it all back together, you have to make sure you get the Tranny's input shaft properly aligned before you push the tranny forward back into the engine or could damage it.
It's easy but time consuming.
RE: Rear Main Seal
ORIGINAL: 95stang5.0
thanks how long did it take you could me and my dad get it in a day?
Dealer had the book at 3.5-4hrs for a clutch or 4 for the straight rear main seal. (The difference was that the 3.5 was for not removing the flywheel/flexplate)
If you have the proper tools, you can do it in a day. Just be sure you have a U-joint compressor, torque wrench, and ideally an impact (air) wrench. The Flywheel can be a real pain in the **** to get off since the bolts are torqued at anywhere between 100-120 ft/lbs. If you don't have an impact wrench, get a 24" or longer breaker bar.
Just be sure to get a Hayes manual for your year car and...TAKE YOUR TIME!
RE: Rear Main Seal
just a note to add, after replacing the rear main, replace the PCV valve as well, reason be is if the PCV valve is gunked up or breaks inside, all the pressure of blow by gases build up and the rear main is the easiest place for them to exit the inside of the engine. I have seen people go through the trouble of changing them and 200 miles later doing it again because the new one was leaking.
09-01-2015 08:16 PM
