clutch problems
RE: clutch problems
i thought about this for a minute,cause my buddy had the same problem then one day we went gear banging....then BOOM! we were like what the hell was that? then the peddle was easy to push in..what we found out was the fork was twisted just enough to cause a bind....what type of qaudrant are you using?
RE: clutch problems
IMO the pressure plate is worn. Happened to me on several clutches on several cars. Whenever it gets worn the pedal pressure increases. The cable has nothing to do with pedal stiffness. The cable controls pedal/clutch engagement.
AmericanMuscle4.6GT
11-10-2015 02:06 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
