Heat Spacers
Heat Spacers
Ok I'm buying the Trick Flow Street Heat upper and lower along with the throttle body adapter for my 94 GT. Should I also buy a heat spacer? They are like $46-$60 from Summit, which is where I'm buying the intake from.
RE: Heat Spacers
well to have a uppe intake that is not cherry red hot...yeah it is worth it...i put one on my cobra...i love it...before you could not touch the upper intake and after i added it i can drive it all day and put my hand on it and it is bearly even warm...i would..
RE: Heat Spacers
It works by separating the metal upper from the metal lower with a "plastic"? spacer. The spacer is less conductive to heat and in theory the upper will be a few degrees cooler. Cooler = denser= more hp. Plus the added space makes the runners longer = more tq. I've heard they have a tendance to cause vacuum leaks.
RE: Heat Spacers
So the 3/8th wont hit? Is there anyway that I can keep my stock hood and have the 1 inch spacer? I would perfer to get the 1 inch, but I don't have the money to get a new hood, so is there anything I can do to get it to fit (more or less) and keep my stock hood?
