Rebuild
Rebuild
well i think the engine is tired of me just flogging it so i think it is time for a rebuild something that is going to handle a more power.
so i just wanted to take the time to see what are peoples prefered rebuild goodies
anyone know of some good brands to look at or the items i should spend just a little mot time thinking about
any information will be really helpful..
its a 302 obviously .. but i will probably going .30 over ... i also have to stay Emissions legal.. Blah.!!..
but yeah please suggest away ..!!
RE: Rebuild
Bang for the buck would be to get a complete rebuild kit, and some better pistons. Maybe a little higher compression, and a decent cam. Check out Summit Racing, Jeg's, buy a MM&FF magazine, go through ads and see what they have. Eagle products are pretty good, but a little expensive. Comp cams, Isky cams, Lunati cams, even Ford Racing cams will do the job. I would probably advise you to find a local speed shop that does machine work, and find out what they recommend, as they will be the place doing the .030 over work, and be sure to have whatever you decide to build, balanced. Sounds like you are rather unexperienced at building such projects, and I would tell you to have the shop do a complete assembly that you can drop right in.
RE: Rebuild
the performance shop that will do your machining should be able to recomeend a setup that will work well together. tell em what you want to do how much you have to spend and away ya go. the build isnt that tough IF you take your time and and READ
