HP gains
RE: HP gains
ORIGINAL: akatsume
Timing advance doesn't do much of a difference unless you got a much modded car. You'll get maybe 3-4 hps maximum I believe. If you really want your timing advance to be worth it, get yourself a good ignition package such as MSD or Performance Distributors' Firepower (which I got and I really recommend it). 14* timing on a boosted ignition does make a difference though. There's this article on the net with a review of the PDF package, check it out The guy states that he did try MSD and Accel before and felt a difference over those two, interesting
http://www.yellowmustangregistry.com/perfdist.html
tell you what, drive your stang for a while with the timing set at 10 degrees, then raise it to 15 degrees, you will feel the power difference.
unless your motor is very tired.
but my old motor had 250000kms on it and I ran 11 bottles of nitrous through it and I could still feel a difference.
not as much as a 75 shot, but you can still feel it.
RE: HP gains
also increases gas mileage,reduce engine temps, and smooths out ur idle only increases mileage if u drive sensibly i was getting 25mpg out of a gt vert w/aod tranny before i swapped to a t-5 a week and a half ago
RE: HP gains
ORIGINAL: silver91gt
I just took my car to a dyno, and with lowering my fuel pressure, and raising my timing to 17 degrees it gained me 20 horsepower, and 21 torque.
ORIGINAL: akatsume
kawiguy827
09-01-2015 07:09 PM
