Car is Possesed
Car is Possesed
Im having this crazy issue with my car.It just cuts off randomly. Ill just be sitting at a light and it will cut off. If i wait betwwen 30 sec and 5 min it starts right up and drives fine. I have checked all wiring, i am getting spark and fuel. When it cuts off it will crank but wont turn over. I do have msd ignition set up on there but everythin is checking out ok. Any help would be greatly appreciated.
I cant drive my car around if i dont know if it will run or not. Its pissin me off.
RE: Car is Possesed
ORIGINAL: firststang@17
RE: Car is Possesed
The starter works but the engine wont start. When it first started cutting off, it would cut off while cruising around 40-50, but now it only cuts off while idling. Ill check those things out. Thanks for all the help.
RE: Car is Possesed
check your dizzy module, mine had same issues and i come to notice it fires up when cold and after afew mins of driving it just dies like not stall or bog out it would just flat out die and afterwards same deal engine cranks and wouldn't fire. i let it cool and fired right up.
I think you could be having same issue check that in the driveway, fire it up in the morning and wait afew mins at idle if it dies with-in 5-10 mins i'de say you have bad dizzy module as it is heating up and then causing the car to die. if so get a shop or yourself to change it i would suggest the stubby torx bit to remove that way you don't gotta pull the distruber and in turn don't have to set to top dead center again but rather lossen dizzy hold down bolt and remove and install new module and then you just have to set your timing again.
let us know the results. worth trying what i explained as i had same type of issues.
RE: Car is Possesed
Distributor Module. Dizzy is short for it. It's could a TFI module, thick film ignition. It's located right on the front of the distributor. It has a wide connector plugged into it.
RE: Car is Possesed
ORIGINAL: 86HOGT
RE: Car is Possesed
It could be the TFI module breaking down, but as I said earlier, that will usually store a code in the PCM. Another item that can break down with heat is the ignition coil. That would not leave any code in the PCM. Or as you've mentioned, a loose connection can have the same symptoms.
RE: Car is Possesed
OH. Okay. thanks. I checked the wires on it and they were a little lose. Ill go ahead and replace it.
ORIGINAL: 86HOGT
