what fuel pump?
what fuel pump?
i have full exhaust an e cam edelbrock intake with 1" spacer throttle body 73mm cl maf sensor cai and 3.55 gears what size fuel pump should i get i have heads coming down the road but which should i get for this setup? also can i just put in the pump alone our will i need a regulator as well? will i get some hp? i can bolt anything on i just have trouble adjusting tuning things how hard is this to do? i was thinking 155 lph.
RE: what fuel pump?
if your current fuel pump is sufficing and you upgrade to accomodate new mods, you wont neccesarrily see a bump in HP. The point of getting a better fuel pump is that when your engine is sucking up more air than the fuel pump can handle. When there is more air than your fuel pump and fuel system can provide to make sure that the air/fuel ratio isnt equal. You will start to lean out when your fuel system is inadequate, which can cause problems. When your leaning out and then you add a larger pump, then you will notice a HP increase as you richen up your fuel mixture.
RE: what fuel pump?
The stock pump is garabage either way, its just enough to support a few mods, I would get the 190 the flow nice numbers as well as a Kirban Regulator, I hada bbk for 4 months and it crapped out it was garabage.... pumps are easy to install too just a stinky *** job.
RE: what fuel pump?
For a $100 bucks you can get a Walbro 255lph from ebay. You'll never have to worry about fuel n/a until you go with forced induction. Fuel pumps are different than a TB in that it only flows what is required by the motor at the given momemt. With fuel pumps bigger is better unlike a TB which may flow more air than your combo needs. The rating number of the pump is its maximum flow rate. Therefore, a given combo may require 145lph. A 155lph, 190lph, and 255lph will all do the job equally with no wasted fuel. But as you continue to mod 155 or 190 might not be able to handle the fuel requirements. Why not change the pump one time and not worry about it unless of course the pump goes bad.
RE: what fuel pump?
ORIGINAL: vfast
the 255 can lead to a rich condition on some cars
mrappe
09-26-2015 10:16 AM
