aod computer in 5 speed.
11-22-2005, 01:10 PM
i did a t-5 swap and did not replace the auto computer with a 5-speed one. i want to buy a superchip which should i get the one for the auto our the 5-speed?
11-22-2005, 02:50 PM
RE: aod computer in 5 speed.
don't waste your money on a chip. just advance your timing and bump the fuel pressure a bit and you'll get the same results.
11-22-2005, 03:28 PM
I ♥ Acer
well if it's a a9p you won't have a problem..
11-22-2005, 04:36 PM
so it won't matter which one i choose also is it really a waste i already have my timing at 14*
11-22-2005, 06:50 PM
If you don't mind me asking what did it cost start to finish on the trans swap? I have AOD also and was thinking about doing them same thing.
11-22-2005, 08:23 PM
about 1500$ but i got an awsome deal on my t5.
11-22-2005, 08:41 PM
I would not go with an off-the-shelf chip. Get it dyno-tuned for a custom chip. It'll be worth it in the long run. As for your other question, you can use an auto pcm in a manual but not vice versa. I believe it because the manual pcm can't send the signal for the tranny to shift. And the other way, the signal sent by the auto pcm is ignored since you manually shift.
11-22-2005, 09:21 PM
I ♥ Acer
just think for 1500 you could be faster in the automatic than the stick[
uedlose
The Racers Bench
10-01-2015 08:31 PM
BeatnikFink
10-01-2015 08:00 PM
Shadow7874
09-24-2015 09:06 PM
mltdwn12
09-23-2015 08:54 AM
Ryan Fitzpatrick
09-14-2015 02:21 AM
