86 heads..worth porting?
Ive read up a little on my motor and I came across that the 86 heads are super restrictive, my question is.. Would it be worth porting these heads and up grading valves etc.. or would I be better off getting some after markets?
RE: 86 heads..worth porting?
You would be alot better going with some aluminum aftermarket heads. ALOT better. But it all depends on your budget. If you dont have the 1000-1300 to spend on a nice set of AFR heads or something than just have them polished. But IMO, I wouldnt. Go with some AFR 165's or 185's.
No , if money is an option, you can always buy some heads off of a newer 5.0. In 1987 ford enlarged the intake tract, and installed less restrictive heads (E5TE and later the E7TE) for a noticable change in HP and torque.
If you wanna spend the money go with the Airflow Research(afr) 165 cc aluminum heads, emmision legal.
Just installed a set of 165 AFRs ,and 1.6 roller rockers on my bros. 86 motor. Called up AFR and told about my concern on the flat top pistons. They recomended a Comp Cam#XE270HR-14,it has dur: 270/276 & 218/224@.50 and lift:.512/.512 with lobe:114.0-------- The car has a stealth/650 holley and a 5-speed. I need to install the 3.73, but it's an ANIMAL!! Good luck!!
TfcCDR
09-14-2015 12:08 PM
