Alternators
Old 12-01-2005, 06:58 PM
88BlueGT
88BlueGT's Avatar
Default RE: Alternators
OK, and you are welcome to post back anytime as long as you dont come back and tell us that you baught the 1 billion dollar alternator that cooks you breakfast
88BlueGT is offline
Old 12-01-2005, 07:46 PM
89stanglx
89stanglx's Avatar
Alternator's are rated at max the stock is like 70 amp and at idle it will be a very low output. As the rpm's come up so does the output up to its max output, i upgraded to the powermaster 1 wire 130amp alternator about 3 months ago, i think i paid around $160 and ordered it from advance auto parts. The stock alternator is junk with my electric fan at idle my battery guage would drop also. Also check those grounds.
89stanglx is offline
Old 12-01-2005, 08:25 PM
Grimace5.0
I ♥ Acer
Grimace5.0's Avatar
ORIGINAL: Derf00
has the Voltage regulator been replaced with the alt every time? I forget what year they actually started including the VR in the alt.
I *think* around 86/87/88 they were included in the alt. My 85 has a external. I'll try to find out for sure.
Just thinking out loud...
Is the belt tensioned properly?
Terminals tight & clean?
Fusible link blown?
Grounds clean?
Grimace5.0 is offline
Old 12-01-2005, 08:41 PM
86HOGT
86HOGT's Avatar
Sounds like something is drawing constantly and making it work harder which can be, as said, bad grounds, a power wire to a component shorting to ground. Like someone else said, are the alternators failing electrically or mechanically, cause that would help to know. Yeah, I work at Ford, and no reman Ford alternator is $400, more like $200+ range, really.
86HOGT is offline
Old 12-01-2005, 09:46 PM
89stanglx
89stanglx's Avatar
6-8 alternators in the past year! omg i cant imagine what this is costing in your electical problems especially if your having garages do the work.. What you need is a boyfriend, please send me pictures and the mods of the mustang lol.
Old 12-01-2005, 09:47 PM
rob_boura
rob_boura's Avatar
has the same problem in my old car 91 hatch 1 alt a month for a year thank god for warenties but remand suck if you have a paw warehouse by you brand new high output altenators run about 130
rob_boura is offline
4cylinderplus2
10-09-2020 07:45 PM
Golfsito
10-06-2015 11:02 AM
MasterLanMan
09-26-2015 10:03 AM
Wombatnation
09-13-2015 09:16 PM
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
Quick Reply: Alternators
