Bettery relocation Sealed or not
i have a 94...so my truck is sealed off from the cabin in a sense.. so to buy a sealed box is pointless correct..? i mean im looking at the difference from a 45 bucks or 120 bucks sealed
RE: Bettery relocation Sealed or not
well if you buy a sealed box you dont need a sealed batter.... if you get an unsealed box you need a sealed battery.... so whichever is cheapest as my understanding of it
As far as I know if the battery is in the trunk, and the area is sealed off from the drivers compartment, you don't even need a battery box. Just make sure that the battery is retained using 2 3/8" fastners to the CAR ( thru trunk floor)
BTW, make sure you have a battery cut-off switch that really works.......
i am in the middle of relocating my battery to my trunk in my 94 GT. and i just bought the kit from summit for like 45 bucks. but my question is, why do you need a cut off switch? why cant you just run everything the way it was in the front of the car just using longer wires and stuff? why cant it be when you turn the key its on? do you really need a cut off switch cut out? whats the purpose?
that summit kit is illegal and wont pass tech.
you need a switch to run at the track. if you never plan on running at any track your fine if you plan on it your fubar
think of a 18ft long cabel that and be rubbed through along its way to the front and short out and catch the car on fire. the switch can shut off the cable and save your car. its pretty much the same reason why they put fuses on an amp cabel in a car
ORIGINAL: Kbush723
so if we are not going to run at the track.. i dont have to worry about the cut off switch..?
