WHEELIE
WHEELIE
Well, im just looking of ways to get my front end ^, it doesnt seem like it lifts up very much, im just asking of things i can do to really lift the nose, ive good tokico blues and eibach sportlines, would i need some drag shocks r springs or sumthing? thanks
RE: WHEELIE
A set of shocks with a 90/10 ratio would really push that front end up, and put more pressure on the back wheels. Along with whatever you can do to lighten the car, especially the front end. Getting traction is a must if you want to do a wheelie or lift the front end up at all, so make sure you have some nice struts and springs in the back, along with tires that grab off the line. Add some power and off the line the front end suspension should push up and give you what you want. But do not do it if you drive your car on the streets alot, with 90/10s you will get little control of turning, it will be hard to go in anything other than a straight line.
RE: WHEELIE
lots of suspension work with less than 350hp or alot of power your choice. i can lift the front about 4-6 inches off the ground with only 282rwhp. but i have suspension setup for drag racing. see vids in sig.
RE: WHEELIE
a 5-speed w/ 4.10's and slicks will do it all stock on a 5k launch. about 4" worth.
or you can add about 3 yards of asphault just in the back , roll backwards on an incline , then pop the clutch at redline like this one i did.
[IMG]local://upfiles/22951/B3D6C7B1821C4572A0F44AFBCAE109A5.jpg[/IMG]
RE: WHEELIE
ORIGINAL: TastePAINt88
this isnt true, you just have to learn what you can, and cant do.
I have 90/10 struts and 50/50 shocks, I got better control and ride now then before with the old stock ones.
