92 5.0 runs great untill under load falls on it ***
I have a 95 mustang 3.8 that fell apart to say the least I also have a 92 5.0 engine,harness comp etc. I swapped everything out of 92 into the 95 except I kept the 5 spd from 95. Engine starts and runs great till I go to move then it falls on its butt. I checked timing 12 deg btdc,fuel pressure 45 un reg 35 reg, Egr has been eliminated, smog pump eliminated, ac eliminated,offroad h pipe with flowmaster 40's all else is stock any ideas? Ign module tested good 9 times
RE: 92 5.0 runs great untill under load falls on it ***
I haven't yet but I will in the AM I was thinking maybe tps but I was wandering something else, what does the pcm calculate load by? vss? tps? maf? coolant tmp? o2. or is it a combo of sensors? And if so which ones
Yeah I just didnt header gaskets and plugs on my car. I also cleaned the Iac and the front of the throttle body. The car starts and runs alright, but when I stomp on the gas it just bogs really bad. Like the motor is misfiring or it is sucking air from somewhere. If you find out what the fix is please let me know.
Its too cold right now and I cant get into bldg at work so I can't check anything till then but I will keep you posted, please do the same ty
Gary Ugarek
63
12-11-2015 02:01 PM
