n20 on 347?
RE: n20 on 347?
motor is still not fired up. Just installed complete Aeromotive Fuel System(sumped tank,filters,#1000 electric pump,regulator,fuel rails,and y-block) running -10an supply line and -6an return line. Ran -10an from tank to y-block,then -8an from y-block to rear of fuel rails,and -8an from driver's middle bottom port /passenger front port on rails to regulator ,then the -6an return to tank. Backing this is TKO ,aluminum d/shaft,8.8 w/33-spline and Pro-Auburn w/c-clip eliminators! Car has upper/lower control arms,drag launch springs w/air bag, frame connectors,QA1 k-member,coil-over conversion w/175lbs, springs,UPRs caster/camber plates,Flaming river manual rack,AeroSpace manual brakes/12" aerospace disc brakes. Hope this gives you more info!! Thanks All!!
YoungStangsMan
09-05-2015 07:01 PM
