Control Arms
RE: Control Arms
I bought them and installed one of them last weekend due to some newbie troubles. It was my first time doing them so it took a litlte longer than expected. I'm going to do the passenger side lower arm tonight and I'll tell you how it goes. Still have to do both uppers tho [:@] I didn't realize it was going to be so time consuming getting all the bolts to line up perfectly. I'll let you know how it goes though...
RE: Control Arms
if they are the Mac ones i have them and only took a couple hours out in the parklng lot to install them myself. made a nice difference in the hatch. i noticed right away how stiff the rear was around bends
RE: Control Arms
Yes ,I have them on my car. 1st time I installed was easy. 2nd time was a pain. I redid my differential and added the poly bushings on the ears w/33-spline axles and Pro-Auburn w/girdle and c-clip eliminators. I was having a hard time aligning the upper bolts on the ears of the differentail. Finally,just remove removed the upper arm. Installed the arm onto the differential 1st.then onto the frame. Little harder when work alone. I was told sometimes need to use straps to align up. I am very happy with their products. Good Luck!!
breaking
10-02-2015 01:27 PM
