Rebuilding "90" Mustang GT
over in cali they have to watch out for highway checks. i have heard. where they have the sniffer on the side fo the road. and when it goes off youll get it. and as far as a 306 if BUILT RIGHT cylinder heads,cam, intake, and so on. look into the articles and featured cars. some of those rides are in the 11s+. just like you said before. you got to know how to TUNE!!!!!. yes it is easier to build astroker to make more power. but you can deff. get some nice power out of a 306. just the same as a 350 is to a 355 in the chevy crowd. its all in the builder...
I'd like to avoid the headache of emissions andleaning to a 302 Stroker engine with 275hp. There are 2 kits below DROP IN MOTOR and LONG-BLOCK spec and pricedoes it seem reasonable?</P>
<P class=Msonormal style="MARGIN: 0in 0in 0pt"><FONT size=3><FONT face="Times New Roman"><U>275 HORSE POWER 5.0 FORD HIGH OUTPUT <FONT color=red>Drop in Motor<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o></FONT></U></FONT></FONT></P>
<UL style="MARGIN-TOP: 0in" ="disc">
<LI class=Msonormal style="MARGIN: 0in 0in 0pt; mso-list: l0 level1 lfo2; tab-stops: list .5in"><FONT face="Times New Roman"><FONT size=2><SPAN style="mso-bidi-font-size: 13.5pt">PRECISION MACHINED 302 ROLLER CAM BLOCK</SPAN> </FONT></FONT>
<LI class=Msonormal style="MARGIN: 0in 0in 0pt; mso-list: l0 level1 lfo2; tab-stops: list .5in"><FONT face="Times New Roman"><FONT size=2><SPAN style="mso-bidi-font-size: 13.5pt">PRECISION GROUND MICRO-POLISHED CRANKSHAFT</SPAN> </FONT></FONT>
<LI class=Msonormal style="MARGIN: 0in 0in 0pt; mso-list: l0 level1 lfo2; tab-stops: list .5in"><FONT face="Times New Roman"><FONT size=2><SPAN style="mso-bidi-font-size: 13.5pt">CONNECTING RODS WITH 190,000 PSI ARP BOLTS</SPAN> </FONT></FONT>
<LI class=Msonormal style="MARGIN: 0in 0in 0pt; mso-list: l0 level1 lfo2; tab-stops: list .5in"><FONT face="Times New Roman"><FONT size=2><SPAN style="mso-bidi-font-size: 13.5pt">Flat Top Federal Mogul PISTONS 9.5 TO 1 COMPRESSION</SPAN> </FONT></FONT>
<LI class=Msonormal style="MARGIN: 0in 0in 0pt; mso-list: l0 level1 lfo2; tab-stops: list .5in"><FONT face="Times New Roman"><FONT size=2><SPAN style="mso-bidi-font-size: 13.5pt">SPEED PRO PISTON RINGS</SPAN> </FONT></FONT>
<LI class=Msonormal style="MARGIN: 0in 0in 0pt; mso-list: l0 level1 lfo2; tab-stops: list .5in"><FONT face="Times New Roman"><FONT size=2><SPAN style="mso-bidi-font-size: 13.5pt">3 PIECE STEEL ROLLER STYLE TIMING CHAIN</SPAN> </FONT></FONT>
<LI class=Msonormal style="MARGIN: 0in 0in 0pt; mso-list: l0 level1 lfo2; tab-stops: list .5in"><FONT face="Times New Roman"><FONT size=2><SPAN style="mso-bidi-font-size: 13.5pt">ROLLER H.O. CAMSHAFT</SPAN> </FONT></FONT>
<LI class=Msonormal style="MARGIN: 0in 0in 0pt; mso-list: l0 level1 lfo2; tab-stops: list .5in"><FONT face="Times New Roman"><FONT size=2><SPAN style="mso-bidi-font-size: 13.5pt">TRUE 1.6 RATIO ROLLER TIP ROCKERS</SPAN> </FONT></FONT>
<LI class=Msonormal style="MARGIN: 0in 0in 0pt; mso-list: l0 level1 lfo2; tab-stops: list .5in"><FONT face="Times New Roman"><FONT size=2><SPAN style="mso-bidi-font-size: 13.5pt">HIGH VOLUME OIL PUMP AND SCREEN</SPAN> </FONT></FONT>
<LI class=Msonormal style="MARGIN: 0in 0in 0pt; mso-list: l0 level1 lfo2; tab-stops: list .5in"><FONT face="Times New Roman"><FONT size=2><SPAN style="mso-bidi-font-size: 13.5pt">CAST IRON GT HEADS. TRIPLE ANGLE CUT, BOWL CUT AND DECKED</SPAN> </FONT></FONT>
<LI class=Msonormal style="MARGIN: 0in 0in 0pt; mso-list: l0 level1 lfo2; tab-stops: list .5in"><FONT face="Times New Roman"><FONT size=2><SPAN style="mso-bidi-font-size: 13.5pt">HARD SEATS FOR UNLEADED OR REGULAR FUEL</SPAN> </FONT></FONT>
<LI class=Msonormal style="MARGIN: 0in 0in 0pt; mso-list: l0 level1 lfo2; tab-stops: list .5in"><FONT face="Times New Roman"><FONT size=2><SPAN style="mso-bidi-font-size: 13.5pt">HEAVY DUTY VALVE SPRINGS, 7 DEGREE LOCKS</SPAN> </FONT></FONT>
<LI class=Msonormal style="MARGIN: 0in 0in 0pt; mso-list: l0 level1 lfo2; tab-stops: list .5in"><FONT face="Times New Roman"><FONT size=2><SPAN style="mso-bidi-font-size: 13.5pt">NEW HEAVY DUTY CHROME MOLY PUSH RODS</SPAN> </FONT></FONT>
<LI class=Msonormal style="MARGIN: 0in 0in 0pt; mso-list: l0 level1 lfo2; tab-stops: list .5in"><FONT face="Times New Roman"><FONT size=2><SPAN style="mso-bidi-font-size: 13.5pt">NEW OIL PAN, TIMING COVER AND CHROME VALVE COVERS</SPAN> </FONT></FONT>
<LI class=Msonormal style="MARGIN: 0in 0in 0pt; mso-list: l0 level1 lfo2; tab-stops: list .5in"><FONT face="Times New Roman"><FONT size=2><SPAN style="mso-bidi-font-size: 13.5pt">HEAVY DUTY FLYWHEEL FOR AUTOMATIC APPLICATIONS</SPAN> </FONT></FONT>
<LI class=Msonormal style="MARGIN: 0in 0in 0pt; mso-list: l0 level1 lfo2; tab-stops: list .5in"><FONT face="Times New Roman"><FONT size=2><SPAN style="mso-bidi-font-size: 13.5pt">BALANCED, BLUE PRINTED, HAND ASSEMBLED BY ASE TECHNICIANS</SPAN> </FONT></FONT>
<LI class=Msonormal style="MARGIN: 0in 0in 0pt; mso-list: l0 level1 lfo2; tab-stops: list .5in"><FONT face="Times New Roman"><FONT size=2><SPAN style="mso-bidi-font-size: 13.5pt">NEW HIGH PERFORMANCE EDELBROCK EFI INTAKE MANIFOLD & PLENUM</SPAN> </FONT></FONT>
<LI class=Msonormal style="MARGIN: 0in 0in 0pt; mso-list: l0 level1 lfo2; tab-stops: list .5in"><FONT face="Times New Roman"><FONT size=2><SPAN style="mso-bidi-font-size: 13.5pt">NEW POLISHED FUEL RAIL</SPAN> </FONT></FONT>
<LI class=Msonormal style="MARGIN: 0in 0in 0pt; mso-list: l0 level1 lfo2; tab-stops: list .5in"><FONT face="Times New Roman"><FONT size=2><SPAN style="mso-bidi-font-size: 13.5pt">NEW EDELBROCK 65MM THROTTLE BODY with Adapter</SPAN> </FONT></FONT>
<LI class=Msonormal style="MARGIN: 0in 0in 0pt; mso-list: l0 level1 lfo2; tab-stops: list .5in"><FONT face="Times New Roman"><FONT size=2><SPAN style="mso-bidi-font-size: 13.5pt">NEW 19lb. FUEL INJECTORS</SPAN> </FONT></FONT>
<LI class=Msonormal style="MARGIN: 0in 0in 0pt; mso-list: l0 level1 lfo2; tab-stops: list .5in"><FONT face="Times New Roman"><FONT size=2><SPAN style="mso-bidi-font-size: 13.5pt">RACE PREPPED FORD DISTRIBUTOR</SPAN> </FONT></FONT>
<LI class=Msonormal style="MARGIN: 0in 0in 0pt; mso-list: l0 level1 lfo2; tab-stops: list .5in"><FONT face="Times New Roman"><FONT size=2><SPAN style="mso-bidi-font-size: 13.5pt">NEW CHAMPION SPARK PLUGS & HEAVY DUTY IGNITION WIRES</SPAN> </FONT></FONT>
<LI class=Msonormal style="MARGIN: 0in 0in 0pt; mso-list: l0 level1 lfo2; tab-stops: list .5in"><FONT face="Times New Roman"><FONT size=2><SPAN style="mso-bidi-font-size: 13.5pt">NEW WATER PUMP</SPAN> </FONT></FONT>
<LI class=Msonormal style="MARGIN: 0in 0in 0pt; mso-list: l0 level1 lfo2; tab-stops: list .5in"><FONT face="Times New Roman"><FONT size=2><SPAN style="mso-bidi-font-size: 13.5pt">NEW DIP STICK AND TUBE 5 QUARTS OF VALVOLINE OIL AND FILTER</SPAN> </FONT></FONT>
<LI class=Msonormal style="MARGIN: 0in 0in 0pt; mso-list: l0 level1 lfo2; tab-stops: list .5in"><FONT face="Times New Roman"><FONT size=2><SPAN style="mso-bidi-font-size: 13.5pt">COMPLETE P.C.V. VENTILATION SYSTEM</SPAN> </FONT></FONT></LI>[/list]<P class=Msonormal style="MARGIN: 0in 0in 0pt"><SPAN style="FONT-SIZE: 12pt; FONT-FAMILY: 'Times New Roman'; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA"><FONT size=2>TOTAL COST $4,899.00 Complete EFI ENGINE<IMG src=smileys/smiley11.gif border="0"></FONT></SPAN></P>
<P class=Msonormal style="MARGIN: 0in 0in 0pt"><SPAN style="FONT-SIZE: 12pt; FONT-FAMILY: 'Times New Roman'; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA"><FONT size=2></FONT></SPAN></P>
<P class=Msonormal style="MARGIN: 0in 0in 0pt"><SPAN style="FONT-SIZE: 12pt; FONT-FAMILY: 'Times New Roman'; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA"><FONT size=2>Their long-block spec is listed below:</FONT></SPAN></P>
<P class=Msonormal style="MARGIN: 0in 0in 0pt"><SPAN style="FONT-SIZE: 12pt; FONT-FAMILY: 'Times New Roman'; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA"><FONT size=2></FONT></SPAN></P><SPAN style="FONT-SIZE:
whoa.
$5k for factory heads? blah
$2.5k for a replacement engine isn't too bad, although you might be able to do better. My friend got a rebuilt 318 for his truck for about $1300. Just scavenge the accessories, intake, and be done.
