Trick Flow Kit..neone?
RE: Trick Flow Kit..neone?
i would rather build my own setup, with some better parts something like TF high ports, AFR's, brodix or canfield ... then a custom grind cam and a systemax or victor intake... just my opinion
Same as above, Id rather mix and match the best parts, a custom ground cam will do better because it matches exactly what you need for your setup. Kits kinda tend to be mediocore, peice together what you see fit.
That is a great kit for the money and a power proven combination,and you would never get near that price with a custom setup hell the heads and custom grind will almost cost just as much then you still have to buy intake,rockers,etc....
ORIGINAL: stangpower96
im not off the blower idea for sure, but this kit is about the same price as a blower, and will perform just as well, it really seems like a good kit.. im not looking for max hp, if i wanted max hp id buy the parts i want.. i want a matching top end, complete kit, for a budget...this kit comes with EVERYTHING, bearings and rings and this is all i need to rebuild my motor and have good power.
But don't forget that you will also need the supporting mods to go along with it too...Like a fuel system,pump,injectors,regulator...then you will also need maf,tb,egr spacer etc.....
