Maf Help..
Old 12-14-2005, 09:01 PM
Black Snake
Black Snake's Avatar
Default Maf Help..
Im such a f*cking idiot. As you all well know im in the middle of my MAF swap and I just got done putting in my fuel regulator and I started with the MAF swap and I couldnt find a hole to put the wires throw so I decided to drill one out, I drilled a hole right under the right wheel and guess what I HIT A GOD DAMN FUEL LINE!!! What do I do? Do I have to replace the whole line?
Black Snake is offline
Old 12-14-2005, 09:05 PM
chord509
chord509's Avatar
Default RE: Uhhh Ohhhh HELP ME!!!!
I don't know of a safer way to do it, personally. That's not something I'd want to trust southern engineering.
chord509 is offline
Old 12-14-2005, 09:15 PM
mallory
mallory's Avatar
if it is just a rubber section of line..i would just patch it....but if it a steel section then i would replace to whole line, to be safe...
mallory is offline
Old 12-14-2005, 10:01 PM
schwindty
schwindty's Avatar
^^^ YOu can buy repair kits but I wouldnt run one on mine, The repair kits require a flairing tool soo its almost cheaper to get the line replaced! Damn that sucks dude! dont worry I have done worse ( Lighting the engine on fire)
schwindty is offline
Old 12-14-2005, 10:06 PM
Topless1995GT
Topless1995GT's Avatar
easy fix, just need 3 things... duct tape, a claw hammer, and the 3rd season of Sanford and Son on dvd.
Topless1995GT is offline
Old 12-14-2005, 10:28 PM
RacerX
RacerX's Avatar
Just need compression fitting,that's all!!
RacerX is offline
Old 12-14-2005, 10:51 PM
cammedlx
cammedlx's Avatar
[sm=angrymail.gif][sm=badidea.gif]
cammedlx is offline
Old 12-15-2005, 12:20 AM
Black Snake
So dont go with the compression fittings? I just baught a couple and see it it works.
What sux is I finished my MAF convertion and am eger to see how it runs, I tryed to turn it on it started up but then died then I noticed a huge puddle of fuel so then I hosed it down and now im trying to figure out what to do.
BTW that MAF convertion wasnt hard at all.
Hey also do I need to do this in the MAF swap? (in red) I dont use cruise control so im just wondering.
[IMG]local://upfiles/15818/9DB4BC0C49D141978C45B9BC08A2E426.jpg[/IMG]
Old 12-15-2005, 01:43 AM
Black Snake
*bump*
Old 12-15-2005, 01:50 AM
waxyourboard
waxyourboard's Avatar
I've tried using compression fittings on brake lines before... yes i know it says not to on the package... and they leaked after oh say... the first push on the pedal
I'm not sure how they'd do on fuel line with 30 to 40 lbs pressure (i think that's right?) You could always go ahead and try it.
Just try and keep sparks away from there... gas is used in combustion engines for a reason
waxyourboard is offline
Quick Reply: Maf Help..
