lugging at 1500rpm
#22
lugging at 1500rpm
wow your dumb look into the FRPP catelog and it will tell your that a b cam is 480
e303 cam @.050 220*/220* lift .498/.498 part # FMS-M6250E303
F303 cam @.050 226/226 lift .512/.512 part # FMS-M6250F303
b303 cam @.050 224/224 lift .480/.480 part # FMS-M6250B303
x303 cam @.050 224/224 lift .542/.542 part # FMS-M6250X303
how does the b cam have that much lift when the specs are right there. hell you dont even have specs of a FRPP cam.
#24
lugging at 1500rpm
Originally Posted by T5superduty
LOL Look at my signature you little nothing. I have a B-303 with a 510 lift... eat that HAHAHA OWNED Twice!!</p>
</p>
#25
lugging at 1500rpm
lol they are just measured with 1.6 rockers which I do not have which mean I have a 510 lift and you got owned twice because you didnt even notice what I was saying... little boy ? Most likely big enough to pick you up by your neck and ring it.<edited><editID>T5superduty</editID><editDate>38001.0702777778</editDate></edited>
#26
lugging at 1500rpm
#30
lugging at 1500rpm
Lift Of a cam does not change the running or idling characteristics of an engine. The only Real characterisic of a cam is the amout of duration and when it happens in correspondence with the pistons. More lift(ie. 1.7 ratio rocker)will only give it more flow on the top end where it is needed and not change duration or when it happens. I have installed B cams myself they are slightly lumpy not bad but with stock gears suck as 2.73 they will bog and act like crap at low rpm'sbecause there is no engine vacuum at that time
