electric fan on my 92
RE: electric fan on my 92
i cant remember the name it was the good one thats in all the mustang mags, that can adjust, i took it back and said it was brocken to get my 300 bucks back haha. well i hope your fan works out better then that mine, it sucks having to change it back once you put it all in.
I had a taurus fan, and all was good, till my thermostatic controller turned the fan on, it kept popping the 30 amp fuse.
those fans pull around 70 amps on initial startup. they do cool it down okay, but it is better to hook up a switch, or use a high amperage relay.
I was pissed to change back to the stock fan on the side of the highway.
the stock one works fine.
some people just hook the fan straight to the battery and a switch.
but going that way you might forget to turn it on.
i have a SN(% fan on my car and i have it hooked up to a temp switch but im going to change that to a regular switch so i can have control of it and also this fan has 2 settings fast and a slow speed
Seanam
10-04-2015 10:15 AM
mrappe
09-26-2015 10:16 AM
09-25-2015 09:06 AM
