heater tube- dealer only?
i need to locate the twin heater tube assy. that runs along the passenger side of the top of the lower manifold. mine is leaking where it attaches to the manifold. anyone ever uy one of these before? if so where did you get it from. thanks, john1614.
RE: heater tube- dealer only?
since it is leaking, just find a fitting with the same threads, and a hose fitting on the top, and use some heater hose, just make sure to put the coolant temp sensor in there.
it will save the hassle of messing with the 2 hoses that go into the heater core.
