I have a 91 Lx that I am about to convert to 5 lug. I want to purchase some of those Cobra R rims. Nothing to big 18" all around with 10" wides on the back and maybe 9" on the front. Can I do this without any modifications like tubbing out the wells? Or rolling the fenders? Or any structural changes. I don't want to go bigger than probaly 18", but how big and wide can I go? I have Apex lowering springs. I think they are only an inch and a half all the way around. I'm sure some of you guys have been here.
Crazy I was just reading about your fuel leak and saw your rims and was about to ask you about them. How wide are your rims? The thin tires are they 35's. I dont know if this help you but I remmeber seeing a special fitting for your situation. You had to find the area and use a pipe cutter, then it was 2 pieces that tightened down on either end the bolted to eachother.
No I have the stock springs for now. You can go 40s in the front but it will limit your truning a bit, you prolly going to have to cut a bit from the inner wheel well.
I have to go with 40's. What if I went with let say 8's on the front and 9.5 or 10 on the back. Do you think that would help? Or is it the height of the rim - 18"?
