REAR END HOUSING BUSHINGS?
im rebushing my rear end as far as upper & lower control arms axle housing bushings the hole nine yards i have a ?? on istalling the bushings in the housing i got them out and that was a bitch but when i install them sould thay stick out even on both ends or sould i go till its flush on the lip end and will thay go in easyer than thay come out cause i would hate to mess up the new ones!!! thanx!
RE: REAR END HOUSING BUSHINGS?
I know what your going through i had the same ****. I used a sawsall to cut mine out but on the new ones i was wondering the samething too so i put them in evenly on both sides and then when you put the rear end back up it should be a closer fit. what kind of bushings did you use?
musnicki
09-23-2015 07:11 AM
Dragonus18
09-09-2015 01:21 AM
09-01-2015 08:16 PM
