A/C Removal!
RE: A/C Removal!
Yes you will still have heat. Just dont remove the blower assembly and you will be fine.
The heat comes from a heater core which is part of your cooling system...not A/C.
Just keep in mind if your car fogs up on the inside your defog will not work nearly as fast because the A/C is not producing dry air.
jwog666
12-27-2021 08:09 PM
