Can't get the fuel pressure down on a 92 notch
RE: Can't get the fuel pressure down on a 92 notch
Well his mentality is that he is only gonna buy a part once... These mods are just the beginning... He just has to deside how big he wants to go with the car.... I can tell you this... its not gonna be close to stock... Either way, it should still not run the way it does... and yes its calibrated to the injectors...
wate a second here, if you have afpr how can it hold vaccum? it has threds in it for adjusting the fuel pressure. if that is the case my aeromotive is no good.[:@]
Well the prob was solved...WITH TWO.......not one but TWO...... BAD BBK regs outa the box... Got a new mallory reg and adjusted it down to 30psi and it pulls hard again... Just had to get the Fuel pressure down for the big injectors.......
mrappe
09-26-2015 10:16 AM
