smog pump yes or no
RE: smog pump yes or no
agreed if you get rid of the smog, loose the cats. do it right the first time, plus the more weight you take off the better which isn't much. of course your car will be alot louder without the cats
I dont know about the 95....but my 92 just needed a short belt and routing it a different way...if you look at it long enough I think you may be able to figuire it out....thats what I did....I could prob show you a picture....but our motors are slightly different.
to find out what size belt you need ( this is how i did it)
cut your old belt then route it around the pulleys just like it was w/ the smog on
and where it over laps either cut it or mark it, then stretch it out on the ground
and measure it and thats the size you need
I cant help you with a correct part number, because i have removed and bypassed my smog pump, removed A/C compressor and relocated power steering pump to where the A/C was with a different bracket but mine is the same belt of a 97 mercury mystique 4 banger without A/C. It should be a sticky though for people asking the correct size belt for smog pump, or A/C delete or both. But deleting the A/C causes the belt to rub on the tensioner on its way down to the power steering pump unless you modify the tensioner.
jwog666
12-27-2021 08:09 PM
mrappe
09-26-2015 10:16 AM
