Talked to a friend of mine tonight he said he'd give me a turbo he had laying arround if I wanted to put it on the stang. My long block has realy low miles and a small cam. Basically a stock block how much boost can it handle? Would the gains be worth it with a single turbo? Im not trying for 450hp just more. Ive seen alot of tt setups not one single on a v8. Any opinion helps
how easy to fab system? and how much boost can a stock block handle? old boy says i can run between 8 and 10psi. safely sound right and is it worth it?
you can run more then that if you run an intercooler which is a must with a turbo. it will be defenitely worth it. if you buy pre-bent tubes and know how to weld, its very easy to fab up a turbo kit. just take your time when laying it out
