cam
cam
exhaust should be longer than intake so you make sure you get all the gasses out of the combustion chamber forcleaner burning of the fuel. compcams is a good cam company <IMG src=smileys/smiley16.gif border="0">
cam
I was looking at this cam from comp cams cause its the biggest cam i can use with my 9:1 compression... 35-226-3 at crane cams. </P>
But everything for the 5.0 is uniform... that cam i was looking at is 230/230 .512/.512 -- I was hoping to find something a little better than could fit my car.. (240/245 .542/.546) Or am I just a dumb ***? Please help me out im just trying to figure out these cams...</P>
Btw, Ive got 1.7 rr so Im kinda stumped on how ill find anything to clear except by getting 1.6 which i dont want to do</P>
</P><edited><editID>Milky</editID><editDate>38001.8727199074</editDate></edited>
cam
well sometime you new more list on the intake side but I do this on hi hp car for a certain set up
milkey...your learning that's why your here...
crower 15512 & 15513
222/228/dur
lift 496/512
rpm 2100-7000
11513
228/234
512/531
1800-6500
these cams thump
comp cam cca-35-514-8
216/224
544/555
1600-5600<edited><editID>vfast</editID><editDate>38001.8972453704</editDate></edited>
222/228/dur
lift 496/512
rpm 2100-7000
11513
228/234
512/531
1800-6500
these cams thump
216/224
544/555
cam
I think I'd like to stay with comp cams, just cause I know they're reliable and agood "name" </P>
I think I'm getting the hang of the cam thing, numbers wise, but I for sure don't know how to calculate for clearance. I've got 1.7 RR's and will soon have AFR 185s. They;ve got the 2.02 and 1.6 exhaust and I don't know how to calculate for clearance and Id rather know its going to clear or change something before Ido the clay and turn over the engine.</P>
How can I juggle these numbers to make sure it clears? Ive got stock stroke and all that... </P>
cam
Haha, sounds good to me then </P>
Do you think I should get my stock pistons cut or since im going this far, replace them with pistons already with cuts? How much is the price difference with the two options.</P>
cam
Instead of going through the piston notching, im thinking about going with the AFR 165s... Twisted Wedge are gonna ned the fly cutting so I think I should forget the 2.02s. </P>
How much trouble would the AFR 165s be with the 1.7s and the bigger cam?</P>
I think it would be worth the improvement over the GT-40s i have. Im not sure if ive got GT-40X or GT-40Y but either way the intake valve is 1.94 which is bigger than the AFRs anyway, and the exhaust valve is only slightly bigger.</P><edited><editID>Milky</editID><editDate>38001.9387847222</editDate></edited>
cam
twisted wedge dont need fly-cut pistons <IMG src=smileys/smiley2.gif border="0">they need flat top pistons or their domed pistons. </P>
