Benefits of MAF conversion?
RE: Benefits of MAF conversion?
it will let the computer adapt to changes you make, mass air cars measure the actual amount of air entering the motor,
the speed density computer you have now uses fuel tables programmed in the computer to control the injectors and other sensors, and it uses load to metermine how much fuel to add.
it will alow you to make a lot of modifcations to your car like heads cam intake and will adjust its self right now you are limited to maybe a intake and a very mild cam befor you have problems with teh way your car runs.
dont forget manifold vaccum it goes off. thats when actually the SD comp gets screwed up
ORIGINAL: silver91gt
is there a way to tell if it is a cali model? i am looking at one but i havent seen it in person. the guy selling claims it has cold air and flowmasters... what do you guys think about this...
http://www.autotrader.com/fyc/vdp.js...g=en&cardist=4
jwog666
12-27-2021 08:09 PM
09-17-2015 07:57 PM
09-10-2015 08:39 PM
09-08-2015 11:50 AM
1986, 50, advantages, air, benefits, benifits, conversion, converting, ford, maf, mass, mustag, mustang, swap, upgrade
