Ratling from lower front end area?
I drove my mustang from the mechanics shop to paint and body today and noticed that the front end was bouncing around a lot. I am assuming I need to replace the struts. I also heard some ratling whenever I hit bumps. Could this also be the struts? Or is it more likely the control arms or spindles or anything else?
Any ideas?
Any ideas?
RE: Ratling from lower front end area?
my 93 lx 2.3 liter did that and I ended up replacing the whole rack and pinion and the control arm bushings and sway bar bushings and that fixe the problem and a way to test the rack and pinion is to each of the front wheels and shake them back and forth and if they movr more than a quater of an inch and makes a noise than i think i would replace that rack and pinion about 130 bucks if its any help!
Cavedawg
09-17-2015 09:51 AM
Dragonus18
09-09-2015 01:21 AM
09-01-2015 08:16 PM
