adjusting timing?
adjusting timing?
Hi, i just got done putting new heads, intake, and carb on my 85 hatchback and i havent been able to get it started. I did have the distributor out at one point to install something and i think that messed up the timing. Its getting fuel and spark but it just cranks and nothing else. Just wondering if anyone can help me get the timing down right so i can finally get it started. Thanks
RE: adjusting timing?
ORIGINAL: 302power
ok thanks. whats the easiest way to get the motor to top dead center?
If your balancer does not have marks on it or you are missing the pointer or if your not sure if the balancer is spun...
Pull #1 spark plug again, straighten a coat hanger and insert it down into the plug hole until it hits the piston. Slowly turn the engine over by hand, have someone hold onto the coat hanger and tell you when it stops coming up. That should be really close to TDC. Do the air blowing out or sucking in first to make sure your on the right stroke though. Don't forget to mark your balancer with paint or fingernail polish or something for reference next time.
09-01-2015 08:16 PM
