The Mysterious Leak
Old 12-31-2005, 03:56 PM
2K929
2K929's Avatar
Default The Mysterious Leak
hey guys, well i have noticed that the ticking noise coming from under my hood has gotten really bad lately. the problem is i cant find a leak in the exhaust anywhere. now, i dont think its a lifter though. it sounds like the noise is right behind the radio or console if you will. anyone ever had this problem. any help is appreciated fellas!!!
2K929 is offline
Old 12-31-2005, 04:53 PM
powerkord
powerkord's Avatar
Default RE: The Mysterious Leak
Is youre car running ok, it could be as simple as a loose plug wire.
powerkord is offline
Old 12-31-2005, 05:35 PM
2K929
2K929's Avatar
yea, the car runs fine. i guess ill just have to have it up on a lift to see whats up.
2K929 is offline
Old 12-31-2005, 05:43 PM
Grimace5.0
I ♥ Acer
Grimace5.0's Avatar
Loose header bolts.
Grimace5.0 is offline
Old 12-31-2005, 06:09 PM
marx91
marx91's Avatar
a blown header gasket will do that
marx91 is offline
Old 01-01-2006, 02:45 PM
2K929
2K929's Avatar
gasket is good and bolts are tight. i dunno. anyone else got any tips? thanks yall
2K929 is offline
Old 01-01-2006, 05:04 PM
vfast
I ♥ Acer
vfast's Avatar
or a empty liquar bottle in the glove box
vfast is offline
Old 01-01-2006, 06:23 PM
Black Snake
Black Snake's Avatar
Just because the bolts are tight doesnt mean theres no leaks, Your header get warped from the heat, or if you baught the crappy Mac headers they thend to have warping problems.
This is what I did, let the car run till it gets hot and get some Heat resistant gloves and start tighting the bolts down I can almost garantee you will get a little play on some of the bolts.
Black Snake is offline
Old 01-02-2006, 08:24 PM
2K929
2K929's Avatar
well all bolts are tight. didnt get much play outta then (even when heated) TIME for a lift!!
2K929 is offline
Old 01-02-2006, 08:31 PM
vfast
I ♥ Acer
vfast's Avatar
start the car have some one cover the tailpipes with thier hand or rag and listen for air
vfast is offline
Quick Reply: The Mysterious Leak
