roller rockers
roller rockers
quick question... what is the stock rr's? is it 1.6 and just the after market rr's just a better quality?
and with 1.7 rr's what would be the performance difference with a H/C/I upgrade. and would 1.7 rr's work with any head combination?
ok so maybe not as quick as i tho't
RE: roller rockers
stock rocker arms are 1.6 and they are tappet not roller,
1.7's will work with most heads, exept twisted wedge (trick flow)
roller rockers are less parasitic than the tappet rockers
1.7's will open the valves more
RE: roller rockers
1.7's need to have enough valvespring for them to work.
If you were runnig a .498 lift cam now and the springs will stack at .510 you will be in trouble. Thats an example.........
Also, you must have enough room when the valve is all the way open for the bottom of the retainer to have .030 clearance minimum from the top of the valve guide.......
RE: roller rockers
PERFORMER 5.0/5.8L WITH 1.90" INTAKE VALVES
Chamber Size 60cc
Intake Port Size 170cc
Valve Sizes (in/ex) 1.90"/1.60"
Bare (single) #60369
Complete (single) #60379
does this help? it's the edlebrock heads
Chamber Size 60cc
RE: roller rockers
ORIGINAL: stanglx2002
just make sure when you do get the RR get the right ones for your heads if i remember right the Edelbrock heads are stud and pedestal mount so get the right RR with the right heads
and the right RR's would be?
69MustangCoupe393cid
10-03-2015 10:33 AM
JDWalton
09-24-2015 08:47 PM
