Caster Camber plates
I think its time I invest in some caster camber plates, I really want some polished or chrome appearing ones but cant find anything, somthing under 200 would be nice. Just looking for some input, or links would be nice, thanks alot.
RE: Caster Camber plates
check summit and jegs....i think the max motorsports and some other chrome ones are $189
http://www.summitracing.com http://www.jegs.com |
upr products or max motorsports
Max motorsports look great, 6bolt, i have to drill holes to install them? there not a direct bolt on? Upr's look cheap, I like the 4 bolt steedas, cant find any chrome ones. More opinions would be much appreacitated, thanks
This is a noob q but what do the CC plates do exaclty?
Ideal for lowered cars, execailly with the sportlines, well here just read mang, these are the ones i think im going to go with, but I want to make sure that I dont have to drill any holes..\\http://cgi.ebay.com/ebaymotors/Maxim...QQcmdZViewItem
I strongly suggest that you check out max. motorsports caster camber plates. I have them on my 94 gt and they are great. You said your trying to stay away from drilling holes but it really isnt that bad. You put the plate on there, line it up with the holes that are already there and then mark the 4th one and drill one hole on each side and your set to go. Its really not that bad and they look great for $189 bucks.. Just my .02
I googled MM CC Plate install and I came up with this. Its a great link. It also has some information on them.
http://www.corral.net/projects/subzero/mmccplates.html |
Thanks. Great site
I got a set of UPR 4 bolts. Very pleased good quality and good price. If you are planning on going with a coil over kit later make sure you get STEEL ones. The aluminum ones would be too weak.
