Transmission Question
My transmission is very notchy when the car is cold. Once it warms up it smoothes out a good bit, but is still notchy. I have an aftermarket clutch quadrant and cable, the pedal has about an inch of freeplay in it. Any help is appreciated.
RE: Transmission Question
no 86gt, you should have some free play, you should be able to use your hand with a light touch and feel where your clutch cable grabs. but emphasize on "notchy" to me notchy can be a number of thinks explain what your trans is doing
It goes into gear, but the effort is pretty high when it's cold. I've always read that 1-1 1/2" of freeplay is recommended. Also, if I try to shift fast at high RPMs it grinds. I'm thinking it might be the syncros.
AmericanMuscle4.6GT
11-10-2015 02:06 PM
LivingInThePast
09-16-2015 12:20 PM
