Intake valve spring problem.
Cant manage to take out the intake valve, I just used the valve compression tool and managed to take out all exhaust valves on my E7's but cant separate the retainers on the intake valves.
Is there a special tool to take out the valves?
Any help would be greatly a appreciated.
RE: Intake valve spring problem.
I would give it a squirt of WD-40 or something like it and go to bed for the night.
Get up. Put head on bench so valve is not going to move (like some rags in the chamber) and then use junky old socket (deep well) and 2lb hammer to hit it making sure valve don't open.
Tool should work fine now......
Can't manage to take the out...[:@] I've worked with cylinder heads before but this is the first time I cant remove all intake retainers, all exhaust valves came out preety quick, I even use a spacer to huld the little cup that holds the retainers while I hammer it but they don't move. I've tried everything from brute force to WD-40 an nothing happens.
What can I do?
What can I do?
TfcCDR
09-14-2015 12:08 PM
09-08-2015 11:50 AM
09-01-2015 08:16 PM
