what is the sign of a mis-firing cylinder?
RE: what is the sign of a mis-firing cylinder?
well i was detonating a while back, but i have since cleared that up, some plugs are normal color and smell, but there was one in particular that was kinda white? stupid question, waht does this mean, is it running lean?
The car will drive in most instances. The most relaible sign is a lost of power, idling problems. The easiest way to check is with a multi meter. Then inspect the cap and rotor for looseness and cracks. Check the continuity of each wire. If there are no problems there inspect your plugs. When was the last time you changed them?
if u had like 2 wires crossed you wouldnt really be able to tell if u werent use to ur car and it was just sitting in the garage or whatever and u started/revved it. I had two wires crossed for a year andthe car sounded fine until i took it on the road and drove it. Got out the firing order and fixed in the OMG what a difference!
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
