mustang suspension
Old 01-09-2006, 03:59 AM
bbf545
bbf545's Avatar
Default mustang suspension
What do you guys use?
Have you used this link for chassis setup? http://www.inductionmotorsports.com/ic.html
Thanks to all that add.. interested in Chassis setup, ride height, if you use a special lower control arm or adjustable upppers?
What about Pinion angle? more better oe worse?
Anyone use ballast in the bumper? 100 lbs/ 125?
Later on!
Les
bbf545 is offline
Old 01-09-2006, 09:03 AM
rsw007
rsw007's Avatar
Default RE: mustang suspension
ive used that site to set my car up. along with info from here www.baselinesuspensions.com all i can say is i have 282rwhp and 379rwtq and cut 1.52 60ft so that tells me it works. see video in sig.
rsw007 is offline
Old 01-09-2006, 01:43 PM
stanglx2002
stanglx2002's Avatar
ORIGINAL: rsw007
what gears and suspension work do you have doen to the car
stanglx2002 is offline
Old 01-09-2006, 07:31 PM
rsw007
rsw007's Avatar
4.10,s with 275/60r15 mt drag radials"28"
front
moroso drag springs "2 coils cut out" with monroe struts for a 4cyl car, upr c/c plates and no swaybar
rear
lowering springs with 1/2 coil cut out, upr double adj. uppers and steeda hardcore lowers.
ORIGINAL: stanglx2002
ORIGINAL: rsw007
rsw007 is offline
Old 01-09-2006, 08:41 PM
stanglx2002
how do you pull off those 60' ft times
Old 01-10-2006, 12:00 PM
rsw007
rsw007's Avatar
stall car up to 1500rpms thaen stab it to the floor and dont let off till im pass the 1/4mile mark. i love the auto just stab and go
rsw007 is offline
NorthAmericanTuning
03-18-2016 11:21 AM
squishbang
Suspension
11-02-2015 03:42 PM
krazykevin
08-18-2015 08:42 AM
robjh22
08-17-2015 07:35 AM
daytooday
08-11-2015 09:22 AM
Quick Reply: mustang suspension
