question about my rod.
i just got 1.7 roller rockers. i was wondering if my stock push rods (they are actually hardend rods that i replaced a few months ago when i did my cam swap)are they the right length. i know this is a newb question but its better to ask then mess up my valvetrain right?
RE: question about my rod.
I would try them. If nothing has been changed since you put the engine togather, it should be ok.
I would aslo be worryed about having enough valve spring for them. Do you have anything 'left' in the strings? Did you even check them when installing the cam?
Also, make sure that you will have slearance between the top of the valve guide and the bottom of the retainer when the valves are all the way open.......
wow thats alot of checks. i know alot of people running 1.7's with my same setup and no trouble. my springs are new trick flows and i bought tall motorsport valve covers.they are the black ones with red writing i think they look sick.
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
