Ford Crate 351w engine...hooker supercomp lt headers....o/r x-pipe...Trick Flow 351w intake manifold....Trick Flow high port heads.....Trick Flow 1.7 roller rockers....Trick Flow cam, 286 intake/294 exhaust duration...42lb. injectors...70mm tb....87mm mass air...accel programmer...What kind of horsepower #'s should i be expecting????</P>
a lot of it, plus tons of torque!!! i would say high 300s, maybe low 400sin hp. but if you are running 42s you need a bigger fuel pump <IMG src=smileys/smiley2.gif border="0">
