'95 5.0 MODS?
RE: '95 5.0 MODS?
I have a 70mm Throttle body but i needed to get the grinder out to make it fit on the stock intake (only do this if you have done porting befor) or use a 65mm on the stock sn95 intake if you do not want to port the intake. I also have a c&l 76mm mass air. and at that time i removed the POS factory air box and put a K&N in the fender. made a big diff in higher RPM power.
I have heard that pro-M also makes a killer MAS ( dont know if they are still around though ? )
I am moving on to engin stuff now ( heads , intake ...)
Matt's 95 Stang
10-05-2015 07:16 AM
