Rocke Arms?
Rocke Arms?
I was wondering when the best time to get rocker arms would be, what size is the most beneficial, and will getting better rocker arms on a basically stock 5.0(minus cai tb exhaust) give some more power to a 5.0.?~thanks
RE: Rocke Arms?
If you put 1.7s on the stock heads with stock valve springs, the springs wont last long. I would go to the junk yard and pull some heads off a GT40 explorer and throw on the 1.7 RR and put it in your ride.
A nice Port and plish job with some new valves would really help in the HP department.
RE: Rocke Arms?
Hi,
Anytime is a good time to upgrade to a set of roller rockers. They will extend valvetrain life and free up a little horsepower. Dyno tests have shown that going with 1.7 ratio rockers over 1.6's will harness a little more power. I can offer you a set of Proform 1.7 Pedestal Mount Roller Rockers that will bolt right up to your current setup for $194.99 shipped to your door. Here is a link
Mustang 1.7 Roller Rockers
Let me know if you have any questions, hope to hear from you soon.
RE: Rocke Arms?
Yeah the RR will reduce friction and like said before you should get some new springs if you get the 1.7. The 1.6 ou wouldnt require them but the 1.7 will add just a little itsy bit of performance since the valves are opening more. Nothing that you can feel on a stock engine but you get the point.
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
